PC does not standby with Microsoft Remote plugged in
Discussion in 'Microsoft Windows' started by RecordablDVDfan, Jun 9, 2005.
  1. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    As subject. The pc will go to standby without it plugged in to a USB input but although the screen blanks the pc is still on with it connected. Using a WinTV 350 tv card with a Nvidia FX5500 graphics card
  2. hutters
    hutters
    Aug 20, 2003
    722
    28
    Cambridgeshire
    +28
    Try a search on S3 Standy on this forum and TGB. There's a number of things that you need to do to get it working properly. It took me a while but I got there eventually :thumbsup:
  3. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Can you explain what you did ? Can't seems to find anything relating to the problem
  4. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Hi mate have you not considered using hibernate instead ?
    If your after power saving you dont save much at all during standby mode as all the fans are still blasting away and the PSU.
    hibernate it saves all your data to the HDD then when powered on its in the exact same position you left it on and will also power up to record live TV.
  5. hutters
    hutters
    Aug 20, 2003
    722
    28
    Cambridgeshire
    +28
    S3 Standby switches off all fans, hard drives, video, etc. It just uses minimal power to keep RAM alive and will allow the PC to wake up to record and update the guide etc.
  6. hutters
    hutters
    Aug 20, 2003
    722
    28
    Cambridgeshire
    +28
    Really - wow!
    You might like to try here then :)
  7. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Hibernate can do all of the above anyway as I use it regular.
    Switches the CPU fan off mmmmmm I doubt that mate or you would have a nice smell coming from your CPU ;)
    PSU fan doesn't switch of either.
  8. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    HIbernate is dodgy, you can corrupt the whole system, standby is much safer
  9. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Tried this thanks but no go, also the keyboard will not standby either as long as the remote is plugged in. The link is 2 years old btw probably not applicable to MCE 2005 anyway
  10. hutters
    hutters
    Aug 20, 2003
    722
    28
    Cambridgeshire
    +28
    Fine, I was only trying to help. The information in that thread got my S3 Standby working just a few months ago so it is certainly not out of date.
    Make sure that you check the motherboard jumpers for the USB ports and the BIOS settings.
  11. TheCrow
    TheCrow
    Jul 16, 2004
    659
    2
    28
    London
    +76
    I use S3 standby daily and it does switch off all fans including CPU and PSU.
    Infact I always leave my HTPC in S3 standby, sometimes for days.
    You can not tell the difference between S3 and being switched off except it will respond to power-up requests from IR and RF remotes and keyboards and it powers-up instantly, no bios boot and no loading from HD.
    Maybe you are confusing this with S1 standby?
    If your motherboard will do S3 give it a go.
    Second thoughts I think you have to install the O/S with S3 enabled in the BIOS for it to work correctly.
  12. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Yep I only have S1 on my PC hence the confusion.
    I use hibernate and don't have any problems at all.
  13. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    I'm told on anorther forum that the bios update for my Asus P4-S533-X mb sorts out the standby problem, anyone confrim this ?
  14. Zephyrius
    Zephyrius
    A colleauge of mine tells me that he had this problem (standby not working from the remote) and searched for a solution - he reckons it was fixed by plugging in the remote receiver before installing Windows MCE.
