PC Crashing randomly when...
Discussion in 'Desktop & Laptop Computers Forum' started by weyland-yutani, Feb 14, 2014.
  1. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,784
    +104
    watching video sources, from streaming. so, i'll be watching a youtube vid and my pc will just crash and reboot. i've reinstalled flash several times but it keeps happening. i uninstall flash and it still happens. i've checked my video card settings and updated the driver, still happens.
    any ideas? thanks,
  2. next010
    next010
    May 29, 2005
    10,838
    163
    +2,127
    So it even crashes when using HTML5 version of Youtube ?
    Thats a hard one to pin down, could be the graphics card is faulty to cause a reboot like that or RAM is faulty, I would do a test with memtest86+ to be sure.
  3. mayuranc
    mayuranc
    Feb 14, 2014
    15
    London
    Is your OS up to date?
    Have you installed any new programs recently?
    Do you get an error after the system reboots?
    Is your system completely functional apart from the crashes that occur when watching a video?
    Have you tried a different browser?
    It would be worth having task manager running when you next try to watch a video to see if the cpu or ram usage jumps prior to the system crashing.
    Sorry for the long list of questions, this is quite an odd issue :S
  4. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,784
    +104
    when the crash happens, the image dies from the pc, but the audio can still be heard playing. that can go on for 30 seconds before the system reboots. it always seems to happen when firefox is open. but not necessarily when firefox is streaming video content, but some video content is playing, either vlc or wmp. wouldn't that point at a video card fault. i'm loathed to do an entire clean install but it looks like that might be the best option to reset all settings. it only started happening recently, maybe a month or two. the only odd thing i have done is remove the windows desktop gadget feature as i had read it was vulnerable. i d/l and ran a tool from microsoft to "fix" it. the problems did occur after that, but no idea if there is correlation.
  5. infinity705060
    infinity705060
    Mar 9, 2014
    5
    4
    London
    Try doing a system restore to a date before the problem started - All Programs > Accessories > System Tools > System Restore
  6. mayuranc
    mayuranc
    Feb 14, 2014
    15
    London
    Just a hunch but can you run memtest and post the results please.
  7. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,784
    +104
    Moot point, now. I tried to reinstall and now the windows instillation wizard says the drive cannot be written to. I have knackered the drive. I backed everything up though. Ordered a new drive.
  8. infinity705060
    infinity705060
    Mar 9, 2014
    5
    4
    London
    Yes, you may have faulty RAM. Can you connect the drive to another PC as an additional drive to see if you can access the folders.
  9. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,784
    +104
    I'll try once I've reinstalled on the new hdd. The system said the drive could not be installed on because it was GDR type drive or something to that effect.
