PC copy to DMR-E50
Discussion in 'Blu-ray & DVD Players & Recorders' started by andyfr, Jun 7, 2004.
  1. andyfr
    andyfr
    Apr 10, 2003
    242
    Highlands, UK
    +4
    I have had a DMR-E50 for a few months now and have been very happy with it. I recently got a Panasonic 9581 burner for my PC and when I tried to copy some files from a disk to watch through the E50 I got a message saying something like "Incompatible Disk". The disk was done by a friend of mine onto a dvd-rw disk and I copied the contents onto a RAM disk. When this didn't work I copied the contents to the hard disk and then used Nero to burn to a -r disk, again the same message. I have been using the same media in the E50 so I know it works fine.
    What am I doing wrong? I can play the files on the PC but not on the E50. I had wanted to be able to record onto a RAM disk and then if I wanted to keep it to copy to -r using the PC. Is this possible or not?
    Thanks in advance for any answers.
    Andy.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    That's odd - DVD-RW can be recorded in two modes: Video (where the file structure is the same as that used on a commercial DVD or a DVD-R) or VR (where the file structure is the same as a DVD-RAM disk). Can you have a look and see what format it is in (Video will include .VOB files whereas VR will have a .VRO file). Regardless though it should have played on either DVD-RAM or DVD-R as these cover both types of file structure.
    There could be a number of reasons why it doesn't work:
    1) The DVD-RW does not confirm to the official pre-set DVD specifications (a possibility if it was authored on a home PC by a novice). This also seems likely if the PC will play it.
    2) The 'ripping' process you use to get the files onto your HDD prior to copying to DVD-RAM/-R is flawed. Have you tried using a programme like DVD Decrypter to grab the files?
    3) The DVD-RW disk is faulty (it is not unknown for sufficient errors to have occurred for one player to still read the disk whilst another will not).
    Have you tried just playing the DVD-RW in the E50?
  3. andyfr
    andyfr
    Apr 10, 2003
    242
    Highlands, UK
    +4
    Hi Rasczak
    Thanks for the reply. I have checked and they are .VOB files. The DVD-RW gives me the error when I try to play it in the E50.
    When I put the files on the hard disk I just copied from the disk to a folder on the hard disk I didn't use any 'ripping' process.
    I haven't tried DVD Decrypter, is it available for download anywhere?
    I have only just got the DVD burner so am a novice where DVD burning is concerned so please bear with me. :rolleyes:
    Andy.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    The DVD-RW is in 'Video Mode' (the same file structure as you would expect on a commercial DVD or a DVD-R) and problems can occur if you just copy it to your HDD. I suggest downloading DVD Decrypter (do a Google search for it - it's free to download/use) to 'extract' the files to your HDD after which you can use a burning ultitlity such as Nero to burn to DVD-R.
    Alternatively you could import it into a programme which supports VR format and export it in a DVD-RAM friendly format - but, frankly, I think this would be a waste of time given it's just one disk and that DVD-Rs are hardly expensive!
  5. andyfr
    andyfr
    Apr 10, 2003
    242
    Highlands, UK
    +4
    Thanks for that. I have downloaded it and will give it a try.
    Next question - sorry :lease: . I recorded a program onto DVD-RAM and have decided to keep it, how do I convert it so that I can burn it to DVD-R?
    Andy.
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Please read my thread entitled "PC GUIDE: DVD-RAM (inc DVD-RW VR Mode) To DVD-R" that is a sticky at the top of this forum. You'll find a guide to an easy method of doing this there (although there are many other ways of doing it).
  7. andyfr
    andyfr
    Apr 10, 2003
    242
    Highlands, UK
    +4
    Thanks very much. :D
    I have printed out the pdf and am just about to download the software to give it a try.
    Andy.
