PC connection to TV via DVI to HDMI cable
G
Gin
I just bought a Panasonic 32LXD60 LCD TV. It has no RGB D-sub connector, but I thought I could connect my PC via a DVI to HDMI converter cable. In the manual, it says that the HDMI connectors are not for PC connection. Is it possible to connect a computer this way to AV equipment, and more specifically to the 32LXD60 TV ?
D
damovo
I have exactly the same question as I am trying to connect my Labtop using XP (had a certain amount of luck when using Windows 2000). I have just sent off an enquiry to Panasonic and await thier e-mail. Have you any news?
Regards
G
Gin
I haven't got a clue, and I don't want to waste my money on a cable to find out if it is possible (if it's not).
Let's hope someone can tell us, or better still, Panasonic can tell you.
