PC connection into PW6
Discussion in 'Plasma TVs Forum' started by Unlight, Oct 16, 2004.
  1. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Hey guys,
    For a while it looks like I'm going to have serious space limitations.
    Can I simply connect my PC to the Panasonic PWD6 via the VGA input?
    If so, does it look ok for games and general useage?
    Any help would be much appreciated :)
  2. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,432
    63
    Andover
    +160
    you can, but the resolution might be a bit off - can't remember what the panny res is but something like 850 x 450, not a standard pc resolution.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    852 x 480 and is fine for video images..... Text (small text is the issue) when using a PC you can go direct into VGA socket leaving other 3 slots free. or use VGA input for something else (PW6 component or RGBHV) from JS box etc and use a DVi card for PC.
  4. stephinson
    stephinson
    Sep 28, 2004
    55
    You will never play games on your computer monitor again
    :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
