Miss Mandy
First time into this section and first time looking at PC building so apologies in advance for any silly questions. I'm basically just thinking out loud here because I'm feeling a little overwhelmed.
Basically I recently moved my PC and thought I'd install a graphics card with hdmi to enable me to use my TV as it's now within reach. I'd previously been using the onboard graphics. What I've found though is that the layout of the motherboard doesn't allow the gfx card to fit due to the fins on it, the power supply is too close to the slot.
I'd like to be able to do a bit of gaming as I've got game pass ultimate and as the PC is 12 years old it got me thinking that it might be time for an upgrade.
So I'm trying to figure out where to start. I don't want to spend a huge amount of money, but I'd like something upgradable in the future. I'd obviously like something better spec than what I've got already if possible. I'm not looking for top of the range and primary use will still be office work and internet browsing.
My current PC is a Dell Optiplex 755 SFF. Its a 3.0ghz core 2 duo with its maximum 8gb ram and 2x 256gb SSD. The gfx I got that didn't fit is an Asus GT 1030.
I think (hope) the SDD and the gfx can be used in the new build so if I've got this right I need to look for a case, a motherboard, processor, ram and a power supply.
So for my use is there a preference between AMD and Intel? What suppliers or retailers are the best for reliability and price? I have never build a PC before so are there any special skills I need or potential problems I need to be aware of?
Thanks in advance for any help you can offer, it's appreciated.
