PC Booting up problem
Discussion in 'PC Gaming & Rigs' started by Baggy69, Jun 22, 2003.
  1. Baggy69
    Baggy69
    Mar 15, 2002
    187
    Birmingham, UK
    +3
    Hi all, My computer has started to do some funny things when booting up recently. It pauses with a message saying 'Verifying DMI Pool Data ..............' sometimes it pauses for a minute sometimes longer and sometimes it freezes completely? The only thing i have done recently was to enable 'DMA' for my hard drive in device manager. I have removed it but still the same??? Any ideas what to try next or anyone know some helpful websites on this? Thanks.
  2. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    which windows are you running 98, ME , 2000 or xp and had you install any new software or updates more info needed
    boogie man:confused:
    edit just found this try here
  3. Garrett
    Garrett
    Apr 21, 2001
    33,628
    2
    167
    The best thief you’ll never see.
    +4,482
    I have just been experiencing a similar fault.
    The cause or what I think is the cause and it has cured it was I had a CD in the same cable as the HD I removed it as it could have been corrupting data. I put it on an other cable and things have been OK since.
  4. Baggy69
    Baggy69
    Mar 15, 2002
    187
    Birmingham, UK
    +3
    running win ME. Done no hardware mods at all for the last 6 months. Just had a quick look at that page boggie man and it looks like thats where i will find my answer. Thanks.
