PC Barcode Scanner?
Discussion in 'Computer Peripherals & Consumables' started by Messiah, Jan 7, 2003.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Anyone know where I could get a reasonably priced barcode scanner (serial, USB?) and software that would allow me to scan all my DVD barcodes into DVD Profiler.
    With some 600 DVDs I don't fancy pulling them all off the shelf one at a time to catalogue them. I got to about 125 and gave up in the hope of being helped out by technology.
    Anyone? Thanks.
  2. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,334
    Doncaster
    +1,127
    try www.maplin.co.uk, and do a search for 'barcode
    it comes up with quite a few - depends what you call 'reasonably priced' though
    dean
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Good idea now we have a spare Datalogic DLL6000-R and OM6010-R at work - I'll just use the wedge cable
  4. Adders
    Adders
    A Serial / USB scanner might not be much use - would suggest a Keyboard Wedge attached scanner. CCD would probably prove to be the cheapest form - Welch Alleyn, MetroLogic, PSC all make such scanners.
    http://www.barcodeman.co.uk/altek/simple/simple.php ... £89.
    Regards
  5. CW1000
    CW1000
    http://www.mavin.com/computermice.html have them for about £16 (inc p&p to UK) for usb, or £11 for PS/2
    They brought up all the cuecat stock when digital convergence went bankrupt.
    They sell the USB and PS2 versions, they are unmodified versions this means that they have encypted output, they can be modified to output unencypted data, very easy to do this on the usb version you just snip on of the pins on the chip.
    All details on modifying the cuecats is on their sites, you can also get a driver that does the decoding if you don't want to modify your cuecat.
  6. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Thanks. Do yo know if the Cuecat software will pass the barcode info to a Windows app such as DVD Profiler?
    Cheers.
  7. CW1000
    CW1000
    Seems to work according to what people have been saying on the dvd profiler forum.
    Hopefully my cuecat will turn up this week, if it does I will let you know.
  8. shodan
    shodan
    Dec 11, 2001
    11,539
    shoeburyness
    +6,432
    If I downloaded the software for my Palm Vx (I know there is program to turn it into a barcode scanner) could I use this for it? Although my collection is pretty small (only about 35-40) and at a push I could probably name them all.... :blush:
  9. shodan
    shodan
    Dec 11, 2001
    11,539
    shoeburyness
    +6,432
    Scrap that, I think I mis-understood! It would appear that you would need a scanner in the first place and the program I thought about just enables you to use the Palm Vx with it!
    Sorry!
    :blush:
  10. CW1000
    CW1000
    My usb cuecat arrived today.
    Just plugged it in and xp used it's built in drivers (don't bother with the cd that comes with the cuecat as thats just the spyware rubbish that digital convergence used before they went bankrupt)
    It works with dvd profiler, you don't even need to modify it as dvd profilers built in scanner plugin decode it's for you.
    When you enable the scanner plugin in dvd profiler it shows a popup, you swipe the cuecat over the barcode, you will then see the encrypted data appear in the box, then almost straight away the plugin extracts the upc and adds it to the collection. So entering multiple dvds is very fast.
  11. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Excellent stuff. Mine was sent yesterday so should have it next week.
  12. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    829
    Derby
    +49
    Hi Messiah
    did you order the cuecat one from www.mavin.com/computermice.html , if yes what did it cost in total with postage to the UK,
    thinking of going for one
    steve
  13. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Yes. $20.25 so I guess about £14.
  14. Alaric
    Alaric
    Mar 12, 2001
    1,759
    Peterborough, Cambs, UK
    +149
    Wow....what a funky gizmo....I've just catalogued 291 dvd's with it - Dvd profiler coped with almost all from the scaner. One ex-rental (spiderman) with a diff code and one (the damned) that it didn't know !
    Anyone know of a similar prog for cd cataloging that uses the scanner ???
    Used the inbuilt driver on win98, didn't mod the scanner and it worked great. Only took a few days (under a week) for it to arrive from Marvins too !
    Cya,
    Lee
  15. Drunken Master
    Drunken Master
    May 12, 2001
    837
    In the middle of a roundabout
    +7
    What a great peice of kit this is and a real steal!!
