pc auto on?
rvdbarnes
howdy
do you guys know if there is a way of getting a pc to come on/off of its own by means of a timer perhaps.
Just so i can schedule maintenence tasks without having to leave it on all the time?
rvd
pragmatic
Yup its in the bios, usualy power managment beside power on keyboard and lan ect... usualy called power on alarm or somthing.
rvdbarnes
and obviously, as long as everything is plugged in, i can set a timer for power on/off.
Just the xp log in screen to get past now!!
wormvortex
remove all the accounts but one, that way u don't get a loading screen xp just boots to that account
gooner#14
how do i disable the windows log in process when i installed it i didnt have 1 set up then a few days later the log in user decided to appear!
wormvortex
did u install microsofts framework? that adds a random profile, go control pannel, users and see how many users are on the list if there you and some other one delete the other one. Not sure what the profiles for but i deleted mine and noting has gone wrong with my pc
Monty Burns
I believe you may be after THIS little bootiful link!
Enjoy! :D
*Get out of jail free: If you break your registry, don't blame me :)
Trending threads
