PC audio -> TV scart - no sound
Discussion in 'Computer Components' started by markav, Jul 24, 2005.
  1. markav
    markav
    Jul 19, 2005
    96
    Got my MCE working reasonably well, but only if I use a set of PC speakers plugged into the green socket on the onboard audio.
    I want to play sound through my TV amp/speakers.
    I have a Y connector, that splits a mini-stereo jack into 2 full-sized phono sockets. I plug that into the same, known-good green socket.
    Then run a pair of phono cables to the TV's SCART (I have one of those scart dongles with a break-out to S-Video and 2 audio phono's).
    Not a peep do I hear.
    Would you expect the signal to work, and I likely have a cabling problem, or am I barking up the wrong tree entirely?
    TIA
    Mark
  2. DaveP
    DaveP
    These scart adapters are usually directional, unless you have a switchabe one.
    Maybe yours is an output version?
    Dave
  3. markav
    markav
    Jul 19, 2005
    96
    Thanks for the suggestion Dave. I do have a switchable one (own lots of lovely gold-plated connecters and plugs from Lectropac, who are just down the road), and the video is going in fine.
    Stranger still, I installed a very old Aureal Vortex 2 card, connected the Y connecter to the audio-out and got sound on the TV.
    Very low volume, so I have to whack the TV volume up to nearly maximum and that introduced hum, so not a real solution.
    But the PC speakers work exactly the same plugged into the Aureal card as the on-board sound. But the connection to the SCART only works (sort of) from the Aureal.
    Confused; you bet.
    Mark
  4. DaveP
    DaveP
    Which on board sound is it? I use Soundmax and it autodetects what is connected. Can you select between headphones/speakers/amp etc?
    Dave
  5. markav
    markav
    Jul 19, 2005
    96
    SoundMAX Integrated Digital Audio. And the strange thing it has burst into life.
    The only thing I did differently, I think, is to boot with the lead to the TV connected. I think before I had booted with either nothing connected or the PC (amplified) speakers.
    Looks like you are dead right and the auto-detect was foiling me.
    TVM for the tip :)
    Mark
  6. rogereye
    rogereye
    May 5, 2009
    4
    Just responding to MARKAV's mention about buying something from LECTROPAC 'which was just down the road from him'. I really need to contact this company but I can't find any phone number or e-mail address for them. Are they still in business - does anyone know?
