PC audio Advice please - Creative Gigaworks S750 or proper Home Cinema system?
Discussion in 'Home Cinema Speakers' started by GAmbrose, Jun 5, 2004.
  1. GAmbrose
    GAmbrose
    Jul 5, 2003
    996
    43
    Essex
    +184
    I'll try to keep this as brief as possible.
    I currently have an Audigy soundcard and some 5 year old Cambridge Audio FPS 2000 speakers. This gives me 4.0 (Quadrophonic) sound, but I think it's time to upgrade.
    The way I see it, I have 2 options.
    Option 1 - Buy the Creative Gigaworks S750 set for approx £250. There are drawbacks to this however. My Audigy only supports 5.1 channel surround sound, and the room isn't exactly ideal for a 7.1 surround system, so 2 of the speakers would goto waste. I've also been told a proper Home Cinema amp and speakers would give me far superior sound. Which brings me to...
    Option 2 - Move the Pioneer VSX859 RDS Amp and KEF 2005 speakers/sub from my main system and hook them upto the Audigy via the 5.1 Analogue inputs (Multi Channel) and then spend £1000 buying some KEF 2005.2 and new Amp of some sort for my Home Cinema system.
    Obviously Option 2 is the more expensive option and would give me excellent sound from my PC, my major concern is are the 2005.2's really noticably better then the original Eggs that I have?
    Basically I am trying to justify spending £750 more than I really need to. I know the 2005.2 subwoofer is supposedly much better, but what of the speakers? Will I notice any difference?
    Gary A
  2. @if ®afiq
    @if ®afiq
    May 31, 2004
    657
    +20
    You're not the only one with that dilema ;)
    I've been musing over this off late and have decided to go the AV route - even though my room is tiny!
  3. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
  4. GAmbrose
    GAmbrose
    Jul 5, 2003
    996
    43
    Essex
    +184
