PC Advise needed
Damo121
I am looking to upgrade from a laptop to a desktop. I will need it for general day-to-day use, ie e-mails and internet but would also like for it to be able to handle light gaming use. Am looking to spend up to £600
Here's one I made earlier on a PC build website:
AMD ATHLON 64 X2 5200+ (2.6GHz) 2 x 1MB L2 CACHE (Socket AM2)
2 COSAIR XMS2 800MHz
ASUS M4N78: DUAL DDR2, S-ATA II, PCIe x16, 2 PCIe 3 x PCI
Windows Vista (Ideally like Windows 7)
500GB SERIAL ATA 3-Gb/s Hard Drive with 8MB CACHE (7200rpm)
22x Dual LAYER DVD Writer
6x BLU-RAY ROM Drive
512MB NVIDIA GEFORCE 8400GS PCI EXPRESS
WIRELESS N 300Mbps PCI Card (Essential)
450W Quiet Dual Rail PSU + 120 Case fan (The quieter the better)
Super Quiet 22dBa Triple Copper Heatpipe CPU Cooler
£500
Please LMK your thoughts and advise.
Many thanks
Damo:)
EndlessWaves
I get £467 for that system (on PCspecialist) so I guess you've added some extra components which you haven't listed - if you want assessments on value for money then you need to list everything to get accurate opinions.
As for the system, I think you've chosen about the worst value for money you could get :).
Get rid of the blu-ray drive, they're far too expensive right now and useless for your stated requirements so I'd wait until they come down to £20 or you need one and then buy and fir it then.
Replace the 5200+, 2GB of ram and 8400GS with better alternatives, you will spend 10-20% more but you'll get a several hundred percent increase in performance when it comes to gaming.
With no blu-ray, a Phenom II X3 720, 4GB of memory and a 4850 (a 4770 would be nicer, but pcspecialist aren't offering it yet) the price changes from £467 to £529, and adding on your mystery £33 that brings it to £552 and the £50 is well worth it. The only possible issue is the noise the 4850 might make so you might like to e-mail PCspecialist about that (when I e-mailed last year they said they used quiet case fans but I didn't ask specifically about the graphics card).
Damo121
Thanks for your advise:smashin:.
The additional items were a Firewire PCI card, Dual Digital TV Card and Anti-Virus software.
Damo121
Howz about this one? I have added a few extras. Cheers. Damo:)
Processor (CPU)
AMD PHENOM™ II X3 720 (2.8GHz) BLACK EDITION (Socket AM3)
Memory (RAM)
4GB CORSAIR XMS2 800MHz - LIFETIME WARRANTY! (2x2GB)
Motherboard
ASUS® M4N78: DUAL DDR2, S-ATA II, PCIe x16, 2 x PCIe x1, 3 x PCI
Operating System
Genuine Windows Vista™ Home Premium 64 bit Edition + SP1, CD & Licence (£75)
USB Options
6 x USB 2.0 PORTS (4 REAR + 2 FRONT) AS STANDARD
Memory - 1st Hard Disk
500GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
2nd Hard Disk
NONE
RAID (HDD 1 & 2)
NONE
1st CD/DVD Drive
22x DUAL LAYER LIGHTSCRIBE DVD WRITER ±R/±RW/RAM
2nd CD/DVD Drive
NONE
Graphics Card
1GB NVIDIA GEFORCE 9500GT PCI EXPRESS
2nd Graphics Card
NONE
Sound Card
ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Modem
NONE, I WILL BE USING BROADBAND
Network Facilities
WIRELESS N 300Mbps PCI CARD (£16)
Floppy Disk Drive
NONE
Memory Card Reader
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Case
STYLISH PIANO BLACK FUSION CASE inc. 2 FRONT USB
Power Supply & Case Cooling
450W Quiet Dual Rail PSU + 120mm Case Fan (£24)
Processor Cooling
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER (£15)
Firewire & Video Editing
3 Port IEEE 1394a Firewire PCI Card (£9)
TV Card
DUAL DIGITAL TV CARD (Watch/Record Freeview on PC)
Monitor
LG W2252TQ 22" WIDESCREEN, HDCP/DVI/2MS/1680 x1050 (£169)
2nd Monitor
NONE
GeForce 3D Vision
NONE
DVI Cable
1 x 2 Metre DVI Cable (£5)
Keyboard & Mouse
NONE
Mouse
NONE
Speakers
NONE
Webcam
NONE
Headsets (VOIP)
NONE
Surge Protection
NONE
Printer
NONE
Anti-Virus
KASPERSKY ANTI-VIRUS 2009 V8.0 - 1 Year Licence for 1 PC (£7)
Office Software
NONE
External Hard Drive
NONE
Home Installation
NONE
Warranty
1 Year Return-to-Base incl 1 Year Free Collect & Return: £5
Delivery
STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI)
Build Time
Standard Build - Approximately 8 to 10 working days
Quantity
£690.00 Delivered.
Shokz
Priced up that same system but with a 512MB HD4850 and it comes to £718, well worth the extra £28 for the boost in gaming performance.
I do call into question the DVI cable at £5 - the monitor should already come with a cable, so maybe you should try to contact PCSpecialist about that. Also, a generic 450W PSU might not be up to powering the HD4850 graphics card, so see if you can find out what brand they use and post it here - any of the good brands should power it effortlessly.
EndlessWaves
Yeah, I doubt you need to specify the DVI cable seperately. They probably won't tell you which PSU they're going to use since like every other PC builder they use whichever units they can get a good deal on but their configurator will warn you or they'll contact you if they feel the PSU couldn't power the system. If you try specifying a higher PSU I think it'll warn you and give you an estimate of what the configurator calculates the system will use.
The 9500GT is another really slow card, if you want to do any gaming it's just not worth going for anything below a mid range 4850/4770/9800GTX+. If you're worried about noise then do send them an e-mail, they may be able to reassure you about the card being quiet when idle or fit a card with a better cooler for a little more, you need to ask about the DVI cable after all :).
EndlessWaves
The GT120 is the 9500GT, see my comments above :)
The Phenoms are also slower than the Phenom IIs and the system costs a fair bit more.
Damo121
Here is one that PC Specialist built for me on my request. Please LMK your thoughts. Cheers:)
Processor (CPU)
Intel® Core™2 Duo E7400 (2.80GHz) 1066Hz FSB/3MB L2 Cache
Memory (RAM)
2GB CORSAIR XMS2 800MHz - LIFETIME WARRANTY!
Motherboard
ASUS® P5N73-AM: DDR2, S-ATA II, 1 x PCI-E x16, 2 PCI, etc
Operating System
USB Options
250GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
2nd Hard Disk
NONE
RAID (HDD 1 & 2)
NONE
1st CD/DVD Drive
2nd CD/DVD Drive
NONE
Graphics Card
2nd Graphics Card
NONE
Sound Card
Modem
Network Facilities
Floppy Disk Drive
NONE
Memory Card Reader
Case
STYLISH SILVER/BLACK TRIDENT MICRO-ATX CASE + 2 FRONT USB
Processor Cooling
NONE
TV Card
NONE
Monitor
LG W2252TQ 22" WIDESCREEN, HDCP/DVI/2MS/1680 x1050 (£159)
2nd Monitor
NONE
DVI Cable
NONE
Keyboard & Mouse
NONE
Mouse
NONE
Speakers
NONE
Webcam
NONE
Headsets (VOIP)
NONE
Surge Protection
NONE
Printer
NONE
Anti-Virus
NONE
Office Software
NONE
External Hard Drive
NONE
Home Installation
NONE
Warranty
1 Year Return-to-Base incl 1st Month Free Collect & Return
Delivery
Build Time
Price (excluding VAT)
£484.35
Price
£557.00
Order Quantity
Bulk discount
£0.00
Total order price (Ex VAT)
£484.35
Total order Price
£557.00
EndlessWaves
Sorry to keep banging on about it but you do not want a card that slow even for light gaming - especially on a relatively high resolution 22" monitor. The only reason to go for cards like that over integrated graphics is if you want extra video outputs and HD decoding support.
Apart from that it seems a reasonable price. The motherboard is a bit old but it'll work and I'd probably upgrade the ram to 4GB and go for the year's collect and return.
Shokz
Haha, yeah, after all that and then they go and suggest an even worse card... *sighs* :rolleyes:
Just go with the 4850 :p
Damo121
Don't be sorry. I really appreciate all this advise:smashin:
I am completely baffled by this technology and am thinking maybe I'll do away with the gaming idea and get a console at a later date.
So to change the story, any ideas for a PC that will handle day-to-day task such as e-mails, internet and word processing etc. It must be wireless enabled and prefably a slime-line case, as I am limited on floor space, and as before, the quieter the better. AMD or Intel? Cheers!:)
Podcast: Marantz SR7015 & NAD T 778 AVR + Mission LX2 MKII Speaker Reviews, AV & Film News and More
