pc (9 pin output)--/--> receiver( 6 inputs, 5.1 dvd)
Discussion in 'Desktop & Laptop Computers Forum' started by jorgem, Jan 12, 2003.
  1. jorgem
    jorgem
    Hi! how can i connect(if i could) ..a 9 pins output with a sony receiver with 6 inputs 5.1 dvd? plese help me..
  2. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    When you say a 9 pin output, do you mean a serial port? If so, no chance :)
  3. jorgem
    jorgem
    i dont know if it's serial port ,it is also call the "Jazz" type plug..... each pin is one of the 5.1 inputs, rear/front/subwoofer/center etc etc.. should i buy a "converter" , destroy my reciever etc?? thanks!
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    I think I know which type plug you mean, probably the same as is on my Abit soundcard. 9pin mini-din, my sound card came with a 9pin to 3 female 3.5 mini jack cable, which I could then plug 3.5 jack to 2 phono leads into.
    Not sure where you'd get one from.
  5. jorgem
    jorgem
    you are right , 9 mini din , i dont know neither where i can get one , but the real important thing that's possible to connect the souncard to the receiver...thanks a lot!
  6. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    +3
    Ah, similar to the PS/2 mouse & keyboard port? No idea where to get a cable from :)
