Question PB-16 Ultra owner - foam plug dimensions
Discussion in 'Subwoofers' started by thinksat, Jul 11, 2019.
  1. thinksat
    thinksat
    Jun 25, 2018
    14
    3
    manchester
    +11
    Hi, I recently purchased a second hand PB-16 Ultra. Unfortunately the previous owner could not find the port plugs and the shipping cost for replacements from the US is $77.00
    I am considering buying some precut foam in the UK but need to understand the dimensions of the OEM foam plugs to best try to match them for a snug fit.
    Any owners of a PB16 Ultra care to take measurements one of their plugs for me?
    Appreciate any responses in advance.
  2. shotokan101
    shotokan101
    Jun 16, 2009
    75,888
    33
    Glasgow
    +25,841
    can you not just measure the diameter of the ports ? :confused:
  3. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    20,781
    Inbetween Upgrades !
    +10,086
    They're 3.5"
  4. thinksat
    thinksat
    Jun 25, 2018
    14
    3
    manchester
    +11
    Thanks, i did not know if they were slightly larger than the 3.5" port to ensure a snug fit as the foam is compressed.
  5. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    20,781
    +10,086
    If they’re cheap enough to get cut get a set of 3.5” and a set of say 3.75”/4.0”
  6. Ed Mullen
    Ed Mullen
    Jan 17, 2008
    45
    +37
    The PB16-Ultra uses 3.5" diameter ports which accept a 4" diameter port blocker.
  7. SonOfSJ
    SonOfSJ
    Jul 8, 2012
    2,296
    116
    Edinburgh
    +1,131
