Pay per view naughty channels
Discussion in 'Satellite TV, Sky TV & FreeSat' started by (GTV)Chris, Mar 13, 2003.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Ok...right.....errr, Um....a friend of mine payed for a night of soft smut on one of the SKY channels.
    err...he said that it asked for his PIN number which I..He ..put in.
    Hey presto...naughty stuff, the wife need never know.
    However, so he tells me, he records the evenings naughtiness and goes to bed....Now then...When he retreves the tape in the morning and views he finds that there is 5 minutes on the tape..it then goes to a load of adverts and then to a blue screen with "Enter PIN Number" displayed.
    2 and a half hours of this was recorded.
    My friend would like to know...how do you eliminate the need to keep putting my PIN number in...I mean his?
    Best
    Chris
  2. Azrikam
    Azrikam
    AFAIK, the pay-per-night channels should only ask you for your PIN number once at the beginning of the night. But, it might also ask you for a PIN number when the programme changes if you've got parental controls set on your digibox. Not sure what the default parental settings are on a digibox, so "your friend" should just double-check the current settings.
    Also, considering the price of a pay-per-night (£5.95 or thereabouts?) compared to the montlhy fee (£8.99), if you're going to order more than 1 a month, you might as well subscribe. But, porn on demand every night can be a little "distracting." :)
  3. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Cheers Bud
    How do you disable parental control???
  4. Mock Turtle
    Mock Turtle
    I watch the more interesting stuff than that but I watch it with my wife.
  5. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Like Challenge TV no doubt :)
  6. Azrikam
    Azrikam
    > Services - Parental Control
  7. B Caine
    B Caine
    Jul 15, 2000
    80
    Barrow North UK
    +3
    You`ll go blind.
  8. diggler46
    diggler46
    Nov 12, 2002
    982
    28
    Nottingham
    +29
    keuys arte gettying hardwer tio swee....:)
  9. Iancity
    Iancity
    Nov 2, 2001
    203
    Ashington, Northumberland
    +6
    I know from . . my friends experience . . that you must be entering your PI before 12.00.
    You need to wait until after the 12 freeview, then you only need enter the PIN once . . . . s o he tells me:blush:
