Pausing & Ketting Kicked Out???
Discussion in 'Playstation Forums' started by Gordie, Feb 10, 2009.
  1. Gordie
    Gordie
    I've just started to enjoy online gaming, but have noticed a couple of issues:
    PSN Home - Often loosing a connection and having to sign back in again.
    FIFA09 - Pausing/stuttering during online gameplay
    RFOM - Can't even get online to play
    Media Streaming - Pausing more frequently than before.
    Also, if I am using the PC upstairs, then going online with the PS3 is just a waste of time.
    I am connected to my router wirelessley.
    Just want to ask:
    1 - Would connecting with an ethernet cable improve it any?
    2 - Would upgrading my 2 year old wireless router help?
    3 - I've read about changing the channel on the router - how do you do this?
    4 - Is there anything else I could try?
    Gordon
  2. derek1971
    derek1971
    Mar 13, 2005
    2,228
    Glasgow
    +300
    I think you will find connecting with a wired connection will improve stability. I used to connect wirelessly and had some problems but have never had any problems since switching to a wired connection.
    I doubt changing the router will make any great difference. If you can try another router just to make sure yours is not faulty then fine but from what you describe i suspect the router is working OK. Some routers have a better wireless signal than others but if you can use a wired connection that will be better.
    How to change the wireless channel depends on the router but generally it is a question of going in to the settings of the router (generally done via a web page) and choosing what channel you want to use.
    As an alternative if the ps3 and router are too far apart to run a wire or you don't want wires all over the house you could try a pair of homeplugs.
  3. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    Just to add that using the internet on your PC while you're trying to game online on the PS3 will affect your game, obviously high bandwidth applications such as iPlayer/BitTorrent will affect it a lot more than things such as normal web browsing.
    Another thing to look in to is your ISP, a lot of them are rubbish!
  4. Gordie
    Gordie
    Hi Derek
    I think you hit the nail on the head. It's stability I am looking for.
    I managed to borrow a 10 meter cable from work, just to see what it was like. I updated "Home" and noticed a big improvement in the download speed. I also tried web browsing (which was a huge difference) and also managed a good 2 hours online gaming.
    So I think I will get a cable (or just forget to return this one to work). :thumbsup:
  5. derek1971
    derek1971
    Mar 13, 2005
    2,228
    Glasgow
    +300
    :rotfl:
    Definitely the way to go
