Pause live TV
Discussion in 'Satellite TV, Sky TV & FreeSat' started by thewilf, Feb 9, 2009.
  1. thewilf
    thewilf
    Dec 13, 2007
    2
    Hi guys,
    I understand there are many threads around about single LNB sky + for appartments and I plan to get a sky+ box from ebay and plug it in to my single LNB. One thing is confusing me.
    If I have a sky + box installed with one feed into tuner 1, a 24/7 recording set up so I can record from a planner by forcing it to go to tuner 1.
    How does the pause live TV feature work, can I still press the pause button on remote and pause TV with this dummy recording part set up?
    Also as far as I have read the sky anytime feature should work with this set up on, is this correct?
    Cheers for all your help
    Will
  2. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    The pause feature will work as long as you are not recording anything else except the "dummy recording".
    Anytime will work providing the box is Anytime compatable but possibly not all downloads will be received as long as you are not recording anything else except the "dummy recording".
  3. pcbbc
    pcbbc
    Jul 23, 2003
    397
    28
    London UK
    +84
    Yes - Pausing and rewinding of live TV uses the tuner currently being used to watch TV.
    Obviously while you are watching, pausing or rewinding TV you can not also be making an unattended recording.
    It works as long as you place your box in standby when not in use (mainly overnight) to free up the tuner to allow downloads. Obviously it won't be able to fill up half as fast with only one tuner available and as a result you may miss some downloads.
