Pathetic X-Box Cable!
Discussion in 'Nintendo Forums' started by john87, May 6, 2002.
  1. john87
    john87
    The only option for 5.1 sound on the X-Box is the Joytech AV cable. It costs £15. At this price quality is expected, yes?
    :mad: Well, its crap! It works OK with the X-Box, but when I switched to my CD player (or any other analogue source) it causes MASSIVE buzzing because its shielding is so crap - everytime I play a CD I have to unplug it.
    That is crap build quality for £15! Doesn't matter how far away you put it, there is buzzing.
  2. dUnKle
    dUnKle
    Jan 1, 2001
    15,480
    +2,382
    Not sure what you mean its the "only" choice
    There are various cables out there, why not import then from someplace like www.dvdboxoffice.com ?
  3. john87
    john87
    Well it was the only choice in Leeds... :( maybe I should of looked around more before getting it.
  4. dUnKle
    dUnKle
    Jan 1, 2001
    15,480
    +2,382
    Yep, I think so :)
    Mine is the S-Video version, official from MS and was very cheap imported from www.dvdboxoffice.com
  5. Dick Scratcher
    Dick Scratcher
    John87,
    I bought the official MS advanced scart cable form Virgin in the White Rose Centre about a month ago. Its optical and causes no interference at all. It is, however, more expensive.
