Quantcast
Patch panel
Stereo Steve
I'm looking to set up a network in my new house to stream music etc. I have cat 5 points in all rooms leading to 1 cupboard where I will have router and switch. I'm looking at patch panels and they all seem to be rack mountable. The cupboard is about 6" deep and I wondered if you could get a surface mount wall box for rack mount panels, ie like a 13 socket box but it fits on the wall, you bring all your cables into the back of it and the rack mount patch panel screws onto it.
I've had a search around google but without knowing what your after it's tricky.
Any ideas?
S
selexus
Hi Steve,
Have a look at www.blackbox.co.uk they have a great range of comms equipment and accesories. Your best bet is to go to the cabinets and racks section.
Cheers.
