Password Protected DVDs ??
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Life_Saver, Feb 15, 2003.
  1. Life_Saver
    Life_Saver
    Dec 14, 2002
    20
    United Arab Emirates
    Can I make a DVD with password protection ?? Like the DVD won't run until you put some numeric password then only the DVD menu will appear ..
    If there is such an option .. which editing software ??
  2. graxxor
    graxxor
    All you have to do is make a menu with 30 buttons, that leads to a second menu with 30 buttons that leads to a third menu with 30 buttons.
    Only one sequence of button pressing will lead successfuly to the final screen.
    You can then make the menu non-skippable.
    www.doom9.org has lots of info on making VCDs DVDs with a great program called Scenarist.
