I have a 701s overhere that is password protected...are there any DIPswitches like on the 808s for example to get rid of this password protection? regards
Open the cover, the release the chassis holding the three main boards. look on the back of those boards directly under where the adjustment buttons are and you would see if it was on in the middle a whole load of flashing lights. If this is a data 701s it's behind a big coil with 4 blue wires coming from it. What you are looking for is a jumper (non wooly type) that needs bridging. If memory serves me right you have to short it to turn the password off. but the words are printed on the board so it's easy to find. Hope that helps
