Passively cooled HTPC- Is this the future?
Discussion in 'Desktop & Laptop Computers Forum' started by mikeaitch, Oct 20, 2005.
  1. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,609
    Stoke
    +56
  2. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Search the forum for it "HFX" alot of reviews on it, I heard it was very picky abut which ATX motherboard to use...
  3. springtide
    springtide
    Oct 7, 2005
    6,800
    +1,963
    Mine hasn't arrived yet (been waiting for 4 weeks) and I still haven't managed to find a Motherboards/Graphics card combination that is in stock.
    Anyone know for a passively cooled 6600 (or 6200) PCi-E graphics card without heatpipes over the top, TV out "and" in stock? Asus, XFX and a few others make then but not in stock? The only card I've found so far that fits the bill is a Gigabyte ATI x700 card from Scan!
  4. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,609
    Stoke
    +56
    Thanx sizzler, will do
    Sprigtide- Overclockers UK have a passive 6600 del 1-3 days
  5. springtide
    springtide
    Oct 7, 2005
    6,800
    +1,963
    Still can't find it at Overclockers:
    http://www.overclockers.co.uk/acatalog/6600.html
    Were you looking at thh 6200? Or AGP?
    Have you spoken to Overclockers? As this is the only place that sells the MSI K8N Neo4 Platinum nForce4 Ultra - PCI-E - 4 PCI slots! Scan Comp have the non-Platinum but doesn't have Firewire!
    I have now managed to find a XFX 6600 cards at Komplett :)
  6. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,609
    Stoke
    +56
    XFX GeForce PCX6600 256MB DDR TV-Out/DVI (PCI-Express) - Retail (PVT43PUDH7) (GX-022-XF) <FONT size=-1>
    Supercharge your gaming with the power of an NVIDIA GeForce 6600 GPU. The NVIDIA® GeForce™ 6600 GPUs deliver best-in-class performance and advanced visual effects for next-generation games. The only GPU in its class with support for Microsoft® DirectX® 9.0 Shader Model 3.0 and with support for PCI Express, the GeForce 6600 delivers ultra-realistic effects, unmatched features, and rock-solid stability so you can play your game the way it’s meant to be played.
    - GeForce 6800 features at midrange prices!
    - Passive Silent Cooling System
    - 2 Years Manufacturer Warranty - Call XFX UK on 08700 553366 or 09068354400 for technical support and RMA services.
    [​IMG]
    Full Specification<FONT face=Arial>
  7. springtide
    springtide
    Oct 7, 2005
    6,800
    +1,963
  8. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,955
    Manchester, England
    +84
    if you can't get hold of one elsewhere keep checking scan for the XFX one - just been ordering some stuff with my dad for his new HCPC and their in-stock/out-of-stock status seemed to change on a daily/hourly basis.
  9. springtide
    springtide
    Oct 7, 2005
    6,800
    +1,963
    Cool :) Thanks very much. I shall keep looking/checking
  10. OneEleven
    OneEleven
    It looks like mediaPC.tv have some XFX cards now too
  11. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,609
    Stoke
    +56
    The HFX dont do the passive cooler for the 7800 :(
    The suppliers have suggested a Zalman flower with slow fan
    What does anyone think? defeating the object?
  12. Skunkpipe
    Skunkpipe
    Not really. Choose the right fan and install it correctly and it should still be quieter than your HDD's
  13. matthew_hallson
    matthew_hallson
    My experience with passive VGA coolers has been mixed... They get very hot and if you put them under load (3d games) you are going to need a lot of active cooling in the chassis to stop them from crashing... which kind of misses the point, as you want a quiet pc, right?
    I have a gigabyte x800 passively cooled card that was fine normally, but when playing games the GPU core temperature would go over 110 degrees, and eventually would crash. The only way to prevent this was to keep 2 x 120 mm system fans running flat out... which made just as much noise (probably more) as an actively cooled card.
    In the end I switched to the reserator, and have not looked back. It may not be pretty, but it is sure quiet.
    Regards,
    Matt
