Passive XBox mod
Discussion in 'Xbox Forums' started by meansizzler, Jan 24, 2008.
  1. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Anyone know any passive mods?, that 70mm fan is way to noisy, was thinking of changing the case but I don't think the xbox CPU has normal heatsink mounting holes, anyone know a way attatch a socket 478/775 heatsink to it? or perhaps a watercooling block?
  2. John
    John
    Dec 13, 2002
    11,620
    +3,279
    have you though about slowing the existing fan down ? I use the overide on XBMC to keep the CPU temp @ 55 , fan speed barely gets above 10%
  3. WBC
    WBC
    Mine slowed right down aswell. On one of my other units I swapped out the fan for a silent, I did need to dremmel in certain areas so it would fit though :smashin:
  4. seXBOX
    seXBOX
    Jan 5, 2009
    100
    16
    Does anyone know the RPM and CFM of the standard xbox fan @ 12v? Thanks:D
