Passive Subs - How to connect?
Discussion in 'Subwoofers' started by Mark Ward, Apr 30, 2002.
  1. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    I've bought a pair of B&WPCS8 THX Passive Subs, together with 3 FCM8 THX Speakers and a pair of SCM8 Surrounds today.
    I bought them because I wanted the amps that were sold with them, but I'm curious to see how the whole setup compares to my current setup. How do I connect up a pair of passive subs, giving the access to the ".1" channel?
    Cheers,
    Mark.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Two options (#2 only applies if the subs have a x-over)
    1. In parallel to the main speakers and the sub is disabled in the setup of the AV amp (SUB=NO) - LFE will be routed to mains and thus to the sub, however all bass and LFE will be duplicated
    2. Speaker out from amp to speaker in at sub, speaker out from sub to speaker - now you can use the internal x-over and bass/LFE will not be duplicated (SUB=NO applies here, too)
  3. Ramius
    Ramius
    Oct 13, 2000
    1,071
    Yorkshire
    +307
    If you have dedicated amps for them, then think of them really as active.
    So from your Denons 'sub out' to the passive subs amp, then onto the passive sub.
    Let your Denon control the show (crossover etc.)
    That's a THX setup.
    Boris
  4. Ramius
    Ramius
    Oct 13, 2000
    1,071
    Yorkshire
    +307
    Reiner's first example wouldn't be advisable. :)
    Wired in parallel with the mains, without a low pass filter or crossover, the sub would be receiving the full frequency range.
    Boris
  5. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Hmm, I only have one sub out, yet I have 2 passive subs. I do have 2 power amp channels available.
    How do I get 2 passive subs, each with their own power amp running from the one Sub Out?
    Thanks,
    Mark.
  6. Ramius
    Ramius
    Oct 13, 2000
    1,071
    Yorkshire
    +307
    Split the sub out signal with a 'y-splitter/connector thingy' then feed each signal into a power amp channel. :D
    Boris
  7. Ramius
    Ramius
    Oct 13, 2000
    1,071
    Yorkshire
    +307
    Is it a bridgeable two channel amp that's capable of driving a 4 Ohm load?
    If so then another way is to bridge the amp, parallel your subs to create the 4 Ohm load and feed the amp with the mono sub out signal.
    (I found the specs of your subs, they've an 8 Ohm impedance.)
    Do you have the amp's specs?
    Boris
