Passive Sub
Discussion in 'Home Cinema Buying & Building' started by blackviper90210, Mar 1, 2013.
  1. blackviper90210
    blackviper90210
    Jan 22, 2013
    Hi all,
    Plus got a brand new set of Onkyo speakers and passive subwoofer for my Onkyo 507 amp.
    Problem I have an subwoofer that is passive and not sure how to connect it? It only has speaker wire connectors on the back of the sub and no phono points.
    Any pointers is gratefully received :)
  2. vidjo
    vidjo
    Dec 4, 2009
    261
    28
    +41
    You need an amplifier connected to the sub output of the Onkyo to feed to your new speaker.
  3. blackviper90210
    blackviper90210
    Jan 22, 2013
    Sorry, not sure what you mean?
    I have a 507 amp and trying to connect the subwoofer to it. The speakers are all connected, but the amp only has phono points for a subwoofer, yet my sub only has speaker connections?
  4. SirTiger007
    SirTiger007
    Apr 7, 2007
    778
    46
    +204
    You can't connect a passive sub to it. You'll need to buy a new sub. I'm guessing that all your speakers are from an older all-in-one system? If so then you should buy a whole new set of speakers too. The all-in-one sets use more power than usual and they may damage your amp if you use them with it.
    I had the same issue. Bought some Jamo A102 speakers.
  5. blackviper90210
    blackviper90210
    Jan 22, 2013
    The speakers were brand new still wrapped and strapped. I was led to believe this was fine for my amp :(
    Being new to this area, took the advice at face value!
    The speakers I know are suitable for my amp, I checked the ohm's of them first.
    So I need an active or powered sub then? Are powered amps all the same, ie do I need to buy a specific amp or most ok?
    TIA
  6. SirTiger007
    SirTiger007
    Apr 7, 2007
    778
    46
    +204
    Which speakers are they? And if the ohms are ok then they should be fine.
    I would think you'd need a powered sub. I don't know of any amps that work with passive ones (though I don't doubt that they exist) I hope someone else will be able to advise an amp for you or know which sub to pair with your speakers.
  7. blackviper90210
    blackviper90210
    Jan 22, 2013
    The speakers are Onkyo SKR-038.
    Thank you for your time and advice, it is much appreciated :smashin:
  8. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
