hi there all, do you think the following can be effectivly cooled passivly?
p4 3.4 Northwood (unclocked if it helped)
Nvidia 6800 GT
I'd also use a passive powersupply - though it would be set to auto-turn when the temp exceded 60 degrees. The fans would be at least 8cm.
I'd use it for HTPC use and it would be left on all the time.
thanks
CaM
Nvidia 6800 GT
thanks
CaM
