Quantcast
Passive 3D
essexboy
I didnt realise if you sat below the screen the 3d doesn't work.
Is this the same with Active?
Jason Shouler
The vertical viewing angle is quite critical on a passive set so mounting position is very important.
It's far less so on an active set.
Note that the horizontal viewing angle is very wide indeed on passive.
essexboy
So what is the optimal mounting height?
Jason Shouler
Perfect, would be mounted flat on the wall with the centre of the screen at eye height (when seated).
If mounting on a TV table stand then it should be at the perfect height by default.
