Passing Blacker than Black, Arcam DV27+
Discussion in 'Blu-ray & DVD Players & Recorders' started by twisted, Jun 28, 2003.
Tags:
  1. twisted
    twisted
    Does anyone know of a way to turn on a test mode in the Arcam DV27+ to allow for the adjustment of contrast / brightness when using VE? It appears that the Arcam DV27+ does not pass a Blacker than Black signal when using VE??
  2. fatbob
    fatbob
    May 22, 2003
    267
    19
    I had a problem with the blacker than black on my dvd player that may interest you.
    I have my player (a Sony 725) connected to my display through RGB, and found that when playing back a PLUGE pattern, my dvd player wouldn't pass blacker than black.
    I then connected the dvd to the tv through s-video, and found that the Sony would now pass blacker than black, but only when connected through s-video, not RGB.
    I then found another trait of the 725 when playing back PLUGE through RGB. I have all the onboard adjustments of my dvd player set to default, colour - 50, sharpness - 50, etc. when I pushed up the onboard brightness control by one notch, the below black bar on the PLUGE appeared out of nowhere. When I reduced it back to midway position, it completely disappeared.
    I now have the equipment connected by RGB, with the dvd players brightness control at one notch above default, and the tv's brightness adjusted accordingly.
    It seems that on my player, its' ability to pass blacker than black is there, it just depends on how it's connected, or, if I'm using RGB, how I have the dvd players' onboard controls set.
    None of this may be relevant to your Arcam, but if it has an onboard brightness control, it might be worth experimenting to see if this works.
    Regards,
    bob.
  3. NicolasB
    NicolasB
    Oct 3, 2002
    6,456
    Emily's Shop
    +898
    Twisted, have you tried tweaking the "below black" setting on page 2 of the setup menu?
  4. twisted
    twisted
    The only thing on Menu 2 is for setting of 0 or 7.5 IRE pedestal setting for black. Neither setting allows for a Blacker than Black signal to pass. I have tried both settings. I'm using the progressive outputs .
  5. fatbob
    fatbob
    May 22, 2003
    267
    19
    The test disk "Avia guide to home theater" uses a test pattern for setting black level that is designed for use with dvd players that cannot pass blacker than black.
    If all else fails, it might be worth seeking one of these out.
  6. thxultra
    thxultra
    Feb 22, 2003
    382
    glasgow
    +4
    i have a dv27+ with the it set to 0 IRE and it passes the pluge test no problem.It was set up with a video essentials test disk, maybe its a problem with your display.Have you tried e-mailing arcam help desk?
  7. twisted
    twisted
    thxultra - which connector are you using and which mode progressive or interlace....
  8. thxultra
    thxultra
    Feb 22, 2003
    382
    glasgow
    +4
    i am using the component outputs above the scart which are the progressive outputs. The component outputs between the scart and the s-video are interlaced only
    hope this helps
  9. twisted
    twisted
    fatbob - was right ... go figure that the '0' setting on the Pioneer plasma was too dark had to bump it up +3 to see it, now setting at +2 on the brightness. Boy talk about feeling stupid!
    I am using the connections above the scart, for progressive component.
  10. NicolasB
    NicolasB
    Oct 3, 2002
    6,456
    Emily's Shop
    +898
    On my DV27 there is an option on the setup menu "Below Black" which has two settings - "normal" and "pass pluge". Maybe they took that off in later (DV27+) firmware versions.
  11. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    We took it off the Vaddis 5 based players as it was no longer necessary; there are a few discs out there with illegal video levels on that upset Vaddis 3 players, so that is why the option was there on those earlier players.
    HTH.
    John Dawson (Arcam)
  12. twisted
    twisted
    So I take it that the Vaddis 5 is handling the RGB side of the house and the something else must be handling the progressive side (Silicon Image?)? ... as I'm able to get a Blacker than Black on the progressive side using VE's test patterns but not when using RGB.
  13. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    could someone please tell me what is the difference between 0 and 7.5 black level modes in the dvd88+ / dv27+ ?
    thanks
    CaM
  14. Chrissywis
    Chrissywis
    Jun 8, 2003
    146
    16
    London
    7.5 IRE should be used for NTSC R1 discs unless you are connected via RGB in which case you should use the 0 IRE setting. Pal discs are unaffected.
