Pass through on Panasonic DVD recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by glover, May 3, 2005.
  1. glover
    glover
    Hi Guys-new to this! I am considering buying a Panasonic DMRE85HEBSM DVD Recorder with hard drive-can anyone tell me if this has 'pass through' via the scart sockets (ie the signal form Freeview box passes through DVD recorder to TV when on standby)? My current Toshiba DR1 has this facility and I need it due to lack of scarts and amount of equipment needed.
    Also-has anyone experienced formatting problems with DVDRam and DVD-RW discs on this Toshiba model?
    Thanks in advance...
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Yes it does.
  3. glover
    glover
    thanks Rasczak......
  4. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    But it won't pass through whilsst recording. ie record from the built in analog tuner and you can't watch freeview. You would have to have a second connection from the freeview to the tv, and some freeview boxes only have 1 scart out?
  5. glover
    glover
    Thanks Ken, the Freeview does have 2 scarts but 2nd goes to VCR and then to TV from there. The Toshiba I have will pass through when recording from analogue... Guess i was lucky with the Toshy!
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Glover,
    Just to avoid any confusion in your original post you asked whether "the signal from Freeview box passes through DVD recorder (E85) to TV when on standby" - that was what I answered for. If we are now talking about whether the E85 has the same feature as the Toshiba, i.e. the ability to ability to watch the Freeview signal whilst recording from the internal analogue tuner, then the answer is No. Toshiba and Pioneer models have this feature.
  7. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    I got lucky with this feature with my Toshiba XS32 as well. I didn’t know in advance that it did this, but I find it useful. While I generally record from Freeview, this comes in useful weekdays at 6:00 when the kids want to watch “Blue Peter” and record “The Simpsons”. I record “The Simpsons” from the analogue tuner, and for that the quality is fine. The XS32 is in “Sat Moni” mode, so they can watch “Blue Peter” at the same time.
    Mark
