Party .. Help needed thanks.
DAZ UK 74
Can anyone help me with how the Party feature works please ?
I have been getting a lot of party invites whilst playing Titanfall. Does this enable the Kinect cam or just microphone? I don't want to appear on cam in my boxer shorts and man boobs on view hehe.
Just need some info on what happens if I accept.
Daz.
King Tones
No one will see you dont worry, that only comes into play if you stream via twitch and even then you can turn it off.
When you get a party Invite just say 'Xbox Launch' and you will go into the party. You should get an invite to the game also.
DAZ UK 74
Thanks KT, when I enter party does it use the Kinect mic or do I still need the headset plugged into the controller ?
omiaho
You have two options either use Kinect mic by default or the headset. However if you go into;
Settings > Kinect
you have the option to disable Kinect mic.
