First stage of room treatment completed.
Black velvet in the first 2m, ceiling and side walls. (walls 2.7m high, ceiling 3.6m wide)
Several changes from my initial idea. Instead of a single piece covering both walls and the ceiling, I decided to cover one wall with a permanent curtain, and use the hook system for the ceiling and the other wall.
In this way, I can have light from that windows if required without removing the ceiling fabric (i.e, I can have it longer without causing a huge conflict)
Also it makes the fabric handling much easier. a 9x2m fabric is quite heavy and with a huge volume. Reducing one third approximately helps.
I have to polish a couple of things. For example the sag is around 10cm in the center. Not too bad but I'd like to reduce it as in a near future I'll use a PJ that could zoom until the ceiling limit itself. I'll probably use some magnets in the center axis.
But so far my PJ has 10cm offset, so I can use it even with this sag.
And now my first impressions...
It is a MASSIVE difference. I knew it was going to improve but hey, not that much!
High contrast scenes are finally watchable. Very nice.
But even the typical dark scenes with dim lights are now much more tridimensional with much more saturated colors (as it happens in a photo when you fix the contrast).
Amazing.
Somehow my old PJ is a different beast and I am considering to extend its life and postpone its renovation (although it is 1080p, it has a 500 ANSI contrast, and 2300-2500 native, so pretty decent and 4k is not a priority considering my viewing distance)
Just a couple of photos comparing with/without treatment. But I insist that even low contrast/APL scenes are now much more pleasant and enjoyable... Anyway these photos are not even close to the feeling when you watch the screen, and perceive the differences (I guess is due to range compression in the iPhone camera)
Thanks for all your help and inspiration...
