Part Exchange deals.
Discussion in 'Photography Forums' started by Johnny Thunder, Sep 22, 2007.
  1. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Could you please give me some advice on a possible new camera deal.
    Do the likes of Jessops do part-ex deals, or would I be better off selling, and then purchasing cheaper on the net?
    I have a Fuji Finepix S7000, and also a Minolta Dynax 505si Super with 50mm lens, and a 70-210 lens plus carry bag and some bits and pieces.
    What sort of price should I expect for them in part-ex or straight sale?
    Thank you.
    John.
  2. tontoshorse
    tontoshorse
    Sep 30, 2005
    3,358
    +693
    Looking at ebay, £100 for the fuji and £50 for the minolta.
    You'd be better off selling them yourself and get a better deal using the queens picture, if you don't mind the hassle.
    A bit like a car really!
    One point though, your stuff is never worth as much as you think!
    Once you've got some readies try here for good prices.
    :smashin:
  3. mij
    mij
    Jan 14, 2002
    3,884
    London
    +999
    Hi, if your lenses are the Minolta AF mount they will work on the Sony A100 DSLR. If your 50mm is the "Minolta AF 50 F1.7" and the 70-210mm is the "Minolta AF 70-210 F4 (beercan)" ? They are both sought after lenses on Ebay and elsewhere. Infact, I would buy the 50mm from you if it is the AF 50 F1.7 and in good nick and at the right price :thumbsup:
    Edit: The Sony A100 with the 18-70mm kit lens is selling new for around £350.00, with your two lenses you would have a good kit assuming they are the compatible type.
  4. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    I'll have to unpack them and check which ones they are.
    Cheers guys.
  5. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,182
    +7,321
    I wouldn't be in too much of a rush to unload the Fuji, it's a fine camera. Unless you've identified a particular weakness then it's quite capable of taking you a long way down the learning curve.
