Question Parasound Halo Hint 6 - opinions?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by belfastbelfs, Aug 19, 2018.
Tags:
  1. belfastbelfs
    belfastbelfs
    Mar 18, 2018
    7
    4
    Belfast
    Hi all,
    I recently came across this integrated amp, which has been released just recently by Parasound. So far from what I've heard and seen on the internet the reviews are really good. Has anybody had a chance to try it? Any opinions would be much appreciated.
    My speakers are KEF R900 and I'd like to replace my Roksan Kandy K3.
  2. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,621
    +4,305
    The Parasound HINT 6 -
    Model HINT 6 Halo Integrated Amplifier « Parasound
    This is a well regarded amp for the money with Improved ESS Sabre32 Reference DAC (ES9018K2M).
    - 160 Watts x 2 @ 8 Ohms (RMS, both channels driven)
    - 240 Watts x 2 @ 4 Ohms (RMS, both channels driven)
    - Asynchronous USB 2.0 supports PCM up to 384kHz/32-bit
    - USB input decodes Native DSD64, DSD128, DSD256 and DoP DSD
    - Coax and Optical inputs accept PCM up to 192kHz/24-bit
    - Analog Bass Management with high & low pass crossovers
    - Phono input for MM, MC and MI with 100 Ω or 47k Ω load
    Stone Audio currently carries Parasound Products.
    Stone Audio - Parasound Halo Integrated 2.1 Channel Amplifier - £2999 -
    Parasound Halo Integrated 2.1 Channel Integrated Amplifier
    I think few amps will match it in that price range for Power, Features, and Quality. Yes, there are better amps, but count on spending more and getting less.
    Steve/bluewizard
  3. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,621
    +4,305
  4. belfastbelfs
    belfastbelfs
    Mar 18, 2018
    7
    4
    Belfast
    BlueWizard, thanks for the reply, I don't think the link above is for the correct amplifier though. There is the new release the new release which is called the Hint 6:
    Parasound Halo Hint 6 Integrated Amplifier
    Does anybody know if there is much difference between the new and the old models? Looking at the specs there is barely any difference
  5. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,621
    +4,305
    The Stereophile Review is from 2015, so it covers the original HINT Amplifier, but hard to find reviews on a just released model.
    I think the HINT and the HINT 6 are basically the same amp with minor improvements. I don't know the specific differences though.
    One minor difference is that the New version has TWO Optical inputs.
    Here is the back panel of the original version -
    [​IMG]
    Steve/bluewizard
  6. eglasb
    eglasb
    Jan 23, 2018
    4
    Brazil
    Here’s the info from Parasound site:
    New Features (Changes from the original Halo Integrated)
    • Burr Brown analog resistor ladder volume control
    • Dimmable front panel volume display
    • Updated USB receiver is Plug and play with Windows 10 and MAC
    • An additional optical input (2 total)
    • Ball bearing supported solid aluminum volume knob
    • Programable default turn on volume setting
    • Favorite volume memory with remote control button
    • Increased phono stage gain for lower output cartridges
    • Improved Left/Right channel separation and balance tracking
    • Updated cosmetics with subtle gold highlights
    It seams it’s almost the same integrated amp with only minor changes.
    Best regards
  7. newlash09
    newlash09
    Oct 6, 2018
    4
    India
    Hi...
    Parasound never expected the original halo integrated to be the big success it is. It was a combination of their dated, but very good sounding P5 pre amp, but with the addition of a modern Ess dac, mated to a power amp section designed by John curl which stood mid way between their A21 and A23 power amps.
    But after the success, and parasound struggling to meet the world wide demand for this amp. They have set upon bringing the dated P5 pre amp up to modern spec. So there is a new parasound P6 pre amp now. And the new hint6 is a combination of the new P6 with same 160W power amp section from the old hint.
    I have the older hint and iam very happy with it. Loads of power on tap, and sounds mellow, and authoratative at the same time. Will buy the hint6 again, if my present hint ever broke down.
  8. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,262
    North east. U.K.
    +1,161
    I think you’ll find that the changes to the preamp section are worthwhile. As Newlash says, the older one, whilst obviously up to the job was a dated design. The new electronically controlled volume control should add a bit too.
    Always wanted a big Halo. Consider me jelly.
