Parasound Halo C1/C2 Global Delay
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by meep, Sep 22, 2004.
  1. meep
    meep
    Apr 22, 2002
    759
    46
    Ireland
    +109
    Hi Parasound Owners/Fans
    Can't find this info anywhere: Anyone know if the C1/C2 processors feature a global delay setting for addressing lip synch problems associtaed with video processing?
    If not, what do people use to ensure audio and picture sync?
    Peter
  2. Arcangel
    Arcangel
    Not at the moment but it's planned for a future firmware upgrade according to posts over at AVS Forum. :)
  3. meep
    meep
    Apr 22, 2002
    759
    46
    Ireland
    +109
    Thanks Arcangel
    Everything else about these units looks perfect apart from this issue :-(
    Peter
  4. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    welll, that and the lack of Pro Logic IIx & Room EQ :)
    CaM
