Parasound A52 or 2205?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by thxgoon, Nov 25, 2004.
  1. thxgoon
    thxgoon
    Does anyone here have any actual experience with either of these two amps? I just ordered the A52 and I'm having second thoughts. Going from a 140 watt denon receiver to a 125 watt power amp with current hungry 4 ohm speakers, do you think I'd be better off finding a quality used 2205? Anybody used both? Thanks.
  2. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    A Denon versus a Parasound :laugh: :rotfl: :laugh: :rotfl: :laugh: The current delivery on the Parasound will blow the Denon away mate, have no fear! Integrated amplifier power output figures are nearly always greatly exaggerated or inaccurate :thumbsup: The power output rating for the Parasound will be with all channels driven and will probably be a conservative estimate at that :smashin:
  3. Xstyle
    Xstyle
    Sep 27, 2004
    3,481
    Berkshire
    +146
    I thought Parasound were budget items ... but good!
  4. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Budget!? You must have a pretty big wallet if you consider Parasound budget. I would consider them affordable high end :thumbsup:
  5. Xstyle
    Xstyle
    Sep 27, 2004
    3,481
    Berkshire
    +146
  6. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hehe, not quite budget :)
    I love my A52 and i'm sure you will too....and it looks soooo nice!
    CaM
  7. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    Those little speakers are certainly budget items,but the amps,from the HCA series to the Halo line are certainly not budget items,with the top line amps topping out in the £4k+ bracket.
    Very well made,good sound and load tolerance....will have no problems with 4 ohm loads.
  8. Hawklan
    Hawklan
    Oct 20, 2001
    6,501
    Essex
    +309
    Yep Parasound power amp would not normally be considered budget even the good old 2205 retailed at £2.5K
  9. rags
    rags
    Apr 13, 2003
    4,089
    London
    +323
    The Parasound amps are top performers. The A52 will eat the Denon for breakfast when it come to driving speakers and sound quality. I have an A51 and you can sense the power in the room !
    The A52 should drive most speakers quite comfortably (I have heard it driving Nautilus 803's) but if you are particularly concerned / your speakers are a nightmare load and you cant stetch to the A51, the 2205 is the way to go. At current second hand prices it is a cracking buy.
    Oh one other thing - Parasound have recently announced a complete revamp of the "classic" series - they are coming out in the next few weeks - something you may want to look into as they are supposed to be substantially cheaper than the Halo line and you might just sneak in the new version of the 2205 at only slightly more than the cost of the A52 (im guessing here).
  10. thxgoon
    thxgoon
    Rags, where did you hear this information about the new classic line coming out so soon? I heard it was coming, but as of yet have heard of no date. Ah well, the A52 is on it's way, we shall see how it does. I can't wait.
  11. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,105
    Norwich
    +789
    I went from a Denon A1-SE to a parasound hca-855a and that was a big jump, then went to a 2205 and that was even bigger, then got greedy and went for a Cinepro 3k6. And if anything it just made me realise how good the Parasound stuff is for the money.
    Enjoy!! ;)
  12. Hawklan
    Hawklan
    Oct 20, 2001
    6,501
    Essex
    +309
    Hi Gizlaroc
    How do you find the Cinepro 3k6 compares to the 2205
    Many thanks
    RON
  13. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,105
    Norwich
    +789
    The cinepro is very good, there is just so much headroom you are never really pushing it, I am using it with an MC8 and a 568.2 before that, and even at -0db it still doesn't break a sweat, it is just very, very, very loud.
    I seriously think it will be my last power amp.
    The 2205 is excellent though and it was only because one of the cinepros turned up and I had heard a friends on numerous occassions that I decided to change.
    Would I have speant £4k on a new cinepro over £2.5k on a new 2205? It would have been hard to justify.
    Would I spend £2k on a used cinepro instead of £1k on a used 2205? definitely!
    The reason I have not really been on the forums for the last 6 months or so is, since having the MC8/cinepro combo I have, for the first time ever, been completely happy with my system, don't realy know how I could get it any better without spending ridiculous amounts of money.
    I know I could get better speakers, but I know what I am after and when a set appear I will grab them, I could go out and spend thousands but I don't want to do that, so I will hold out.
  14. NMyTree
    NMyTree
    Jun 17, 2004
    105
    16
    Yankville, Whanker USA
    Parasound Halo A21 to drive your fronts, and the Halo A51 to drive your Center and Surrounds.
    "Heaven.............I'm in Heaven........" :laugh: :D
  15. Henry
    Henry
    Aug 9, 2000
    2,162
    Hull
    +52
    Interested to know what speaker set you're after?
