Parasound 2205 Showing "HighTemp" on CH3
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by jlcrawford, Jan 25, 2003.
  1. jlcrawford
    jlcrawford
    Mar 21, 2001
    491
    NE England
    +3
    I bought this S/H so it is out of warranty but I think the problem is a loose/faulty thermostat thingy as the warning light comes on almost immediately and can flicker or go off.I have channel 3 driving my left rear so it is not getting overworked.
    Anyone got experience or advice on what to do- can I open it up and check for loose connections?
