Parasound 1205
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by stoke1975, Aug 19, 2004.
  1. stoke1975
    stoke1975
    Feb 8, 2004
    788
    Madeley, near Crewe
    +18
    I currently run a Pioneer AX5 in 5:1. I also run alongside, a Naim 82 pre amp, into a separate stereo power amp to drive the front speakers.
    I have ordered a Parasound 1205 to use alongside the pre amps of the pioneer to improve the quality of signal to the speakers.
    Can I dispense with the stereo amp and use two channels of the 1205 and still incorporate the Naim 82 pre amp for stereo? how would this be done?
    Neil
  2. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    If the Naim has an AV passthrough you can do it. Or just use one of the inputs at a set volume. The other option is to buy a switch box so you can have the Naim and the Pioneer connected and switch as required.
    I'm trying to find a good preamp with AV passthrough, no luck yet though.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,019
    The Borders
    +3,161
    stoke1975
    If a high quality switcher is not deemed too expensive for your requirements we have the Zektor MAS3 which will do what you require and switch your Pre Amp and AV Processor to your multi channel Power Amp.
    Although conceived and marketed for use as a Multiple 5:1 Source switcher the MAS3 will work equally as well for your requirement.
    See http://www.zektor.com/mas3/
    Best regards
    Joe
