Paradigm sub
Discussion in 'Subwoofers' started by lunker, Jun 6, 2002.
  1. lunker
    lunker
    I've just got a Paradigm PDR8 sub from richer sounds and I loved it! I've had 3 subs now and this by far the best. The problem is I left my telephone (BT DECT phone) on top of the sub but when the phone rang the usual high pitched ring had a nice bit of bass behind it. After that the sub has started buzzing I've moved all electrical equipment away from the sub but it still buzzes. What haev I done and how can I reverse it???:confused:
  2. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    Don't know what youv'e caused,but if after a shutdown if the symptom is still present,i'd return to RS for advice (replacement).
  3. stranger
    stranger
    subs and speakers will pick up a mobile phone,mine went off in miller bros. next to 4 rows of tvs-what a racket. my two pdr 10s have a low hum when on, nothing that you can hear unless you are on top of it. i don't think you've done it any harm but if you like the 8 swap it for the 10 which will stand later upgrades.and give you deeper bass.
