paradigm speakers
Discussion in 'Subwoofers' started by philmate, Nov 11, 2000.
  1. philmate
    philmate
    Nov 6, 2000
    216
    Southend-on-sea
    +4
    Hi There,
    Need some advice, I'm thinking of buying PDR10 sub, Atoms and either ADP150/170 speakers,(If I can get a demo).Does anyone have these and if so any advice would be most gratefull. Also at the moment I have my processor set to no centre speaker and it sounds ok. What difference would one make as my mains are only 7ft apart. Kind regards.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    IMHO having a center speaker is more importanmt than having a sub, even if a sub. makes more of an impact initially.
    My front pair are about 5ft apart and I can still hear a increased difference in panning etc when I have my center running.
    Definately get one!
    As for the Paradigms, they rae good if you can actually get hold of them. Richer Sounds are doing an extremely poor job at the momment. Half their (Paradigms') has to be imported specially which means they cost a lot.
    Sort yourself out Richer Sounds!
    Rick
    'I am just a figment of your imagination.'
    MiB 1997
    Work Site: The Sound Gallery
    Home Site: WD A.V.
  3. Jesus H
    Jesus H
    i remember now
    i was waffling on about paradigm centre speakers, when the topic clearly did not concern them, i only realised this after i'd posted the message and deleted it
    'This one's got a bad mmooooooooooooooooootivaaaaaaator (in a very camp voice)'
