paradigm servo
Discussion in 'Subwoofers' started by spicymackerel, May 15, 2002.
  1. spicymackerel
    spicymackerel
    any websites where I can buy servo on mail order ? - appreciate details
  2. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    Richer Sounds are the European distributor for Paradigm but no products appear on their website.
    You´ll need to contact a branch directly or ring the mail order number and see what they suggest (they may take the order).
    cheers
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Don't you have a local RS? ;)
    If not try
    http://www.richersounds.com/cgi-bin/search.cgi?load=frame
    The Paradigm is a bit different and not on the web site but there is a phone number etc, this might be your best bet.
