paradigm ps1000 manual
Discussion in 'Subwoofers' started by mickey, Feb 28, 2005.
  1. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    HI , just aquired a paradigm ps1000 sub but without any manual to aid in my setup of said sub, Does anyone know where i can download one from?, I have been to the paradigm site and cant find no help there at all :( . cheers Mike
  2. gjc-ortho
    gjc-ortho
    Feb 28, 2004
    1,493
    Bridgend
    +111
    mickey,
    I *may* have one of these at home, if I can find it I'll scan it for you and let you know.
    Cheers mate
  3. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    cheers M8 , if you have that would be great.
    Mike
  4. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    48
    Leicester
    +56
    From memory the manual that comes with this is just a 4 page booklet that covers most of their budget to mid range speakers. I've got 2 or 3 of them at my other place but will not be back for a coupe of weeks. Happy to send you one though when I get home. However, I think you would be better off just reading through some of the sub threads here and you should be able to set it up. A lot of the set up is trial and error with subs anyway.
    I also have a PS1000 and for starters try putting the volume up to half way setting the crossover at half way and the LFE level on your receiver to about -12dB then tweak from there. Very enjoyable subs for the money so I'm sure you'll be impressed.
  5. gjc-ortho
    gjc-ortho
    Feb 28, 2004
    1,493
    Bridgend
    +111
    Mike,
    Found it, scanned it and produced a .pdf. PM me your e-mail and I'll get it to you.
    Cheers Mate
  6. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    Thanks for all the help and advice guys hugs and kisses to gjc. ;) cheers Mike
