PARADIGM PS1000(how much?)
Discussion in 'Subwoofers' started by vulkan75, Nov 6, 2005.
  1. vulkan75
    vulkan75
    Hi guys,just seen one of these on flea-bay and just wondered what would be a fair price to pay.
    I'm aware they are few and far between but I cant seem to find a previous auction to get an idea.
    Anyone bought or sold one of these??
    cheers :confused:
  2. kbfern
    kbfern
    Aug 17, 2002
    17,953
    Wolverhampton
    +6,128
    The sort of price these seem to go for on this forum would be £100-£140,remember there are versions 1,2,3 and I think they had a version 4 released this year.
    Excellent sub for the money second hand,I have one myself in one of my systems.
  3. vulkan75
    vulkan75
    Does the version make a difference to the price then?? I'll have to ask as to which one it is..
    cheers :smashin:
  4. kbfern
    kbfern
    Aug 17, 2002
    17,953
    Wolverhampton
    +6,128
    Version 1 will be around 4/6 yrs old where a version 3 will be maybe 1-3 yrs old.Version 3 and 4 are updated and sound better than v1 & 2.
    I would pay no more than say £90-£100 for V1,£100-£110 for a V2 and £100-£140 for the V3 & 4.Carriage should cost no more than £15.
  5. vulkan75
    vulkan75
    Yup,its a version 3,so should go for the norm.It dosn't seem to have many bids though.I think i'll hang on and proxy bid at the end.
    thanks for the pointers. :cool:
  6. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
    Apologies if hi-jacking the thread
    Just bought one, but no manuals etc etc. In a dark situation how to wire-up this to my AV receiver (sub pre-out). I've tried to plug-in AV sub pre-out to Paradigm pre-input (RCA). Bit boomy and i can hear only extremely low bass but not real punch.
    Also my AV receiver has only one sub-out and Sub has inputs for left and right channels.
    Any help much appreciated
  7. kbfern
    kbfern
    Aug 17, 2002
    17,953
    Wolverhampton
    +6,128
    You can plug the phono (RCA) lead from the receiver out to either the left or right phono in on the sub.
    The manual is very basic and tells you very little so don't worry you dont have it.
    Suniil what settings do you have your sub and receiver set at and what make/model is the receiver and what speakers are you using?
  8. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
    Toshiba SD350 DVD player, Marantz SR5200 and Paradigm Ps1000 subwoofer.
    SD350-->digital coaxil-->Marantz Digital input-->subwoofer out-->phono-->PS1000
    All controls on sub i've kept in middle
    Regarding speakers i've not yet bought, but hookedup existing panasonic speakers came along with 1 box system (SCHT520)
  9. kbfern
    kbfern
    Aug 17, 2002
    17,953
    Wolverhampton
    +6,128
    You need to set your receiver sub crossover output to 80hz(if it will go that low) and set the main speakers to small for starters.Set the receiver subwoofer output to 0db.
    Then turn the subs crossover knob to max (around 125hz)then everthing below 80hz that the receiver outputs will go to the sub.Sub gain (volume) should be around half way and sub phase knob turn to 0.
    This should be your starting point and you can tweak from there.
  10. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
    Thanks very much for the tip
