Paradigm PS-1000
Discussion in 'Subwoofers' started by MattTheCat, Jun 3, 2002.
  1. MattTheCat
    MattTheCat
    Apr 20, 2002
    79
    Cambridge
    I am seriously considering this sub, for 50-50 use with music and movies. It is said to be a bit crap for music, but I was wondering if anyone has tweaked/moved it to make it sound complimetary to their system for music?
    My system:
    Sony DVP-NS300 DVD Player
    Marants SR6200 Receiver
    Wharfedale Diamond 8.1 Rears
    Wharfedale Diamond 8.3 Fronts
    Wharfedale Diamond Centre
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,492
    United Kingdom
    +2,029
    You need to send a PM to Spectre (the Adminstrator) to see if he´ll change it for you, only he can.
    The Paradigm isnt bad for music it just needs tweaking. The best thing to do is place the sub at your listening position, play some music with decent bass, then wander round the room to find where the bass sounds the tightest and deepest (or the best to you!!), when you find the spot, place the subwoofer there. Its also worth playing around with the phase as this can make a bit of difference to the overall sound.
