Paradigm PS-1000 HOW CAN I TELL WHAT VERSION IT IS
Discussion in 'Subwoofers' started by richie007bond, Mar 7, 2006.
  1. richie007bond
    richie007bond
    Oct 5, 2005
    144
    Isle of benbecula
    +27
    hi guys am thinking off buying a second hand Paradigm PS-1000 and i would like the lastest verision which is 3,how do i tell what version is which any help would be greatly apperciated,thanks guys i look forward to any help uncan give me..kind regards..richie:lease:
  2. kbfern
    kbfern
    Aug 17, 2002
    17,929
    Wolverhampton
    +6,093
    It should say on the back if its a version 3, it will show V.3 in the serial No.Also the top of the subwoofer is rounded off,earlier versions are square.
    Great sub for the price,would expect to pay no more than £130 ish for a V3.
  3. richie007bond
    richie007bond
    Oct 5, 2005
    144
    Isle of benbecula
    +27
    hi kbfern could u tell me how much of a difference ver 3 is to earlier models 1,2 cheers..kind regards..richie
  4. Canada Dave
    Canada Dave
    Hello,
    I own a V4, which is a different animal than previous versions. The V4 is more musical (not boomy) compared to previous versions, thanks to a redesigned amplifier and driver. A high-end home theater shop owner told me amplifier quality can make or break a sub and he said the new amplifier in the V4 is of much higher quality than the previous versions. The driver has greater excursion than previous PS-1000s. Having owned both a V2 and a V4 I can say I greatly prefer the V4 for its tightness with music. Older versions are fine if you mostly watch movies, but for both music and movies I'd look at the V4.
    My friend hated my PS-1000 V2, calling it "in your face." He listened to my V4 with music and his jaw dropped. He said there was no comparison.
  5. Tuco
    Tuco
    Feb 11, 2002
    238
    +23
    Are there any easy mods to reduce the boom in the earlier versions ?
