Paradigm PDR-8 Feedback advice
Discussion in 'Subwoofers' started by jamieperryman1, Aug 5, 2005.
  1. jamieperryman1
    jamieperryman1
    Hi there
    My paradigm PDR-8 sub keeps.......well it can best be discribed as feeding back. The low noise start fairly quietly and then gradually builds till it is shaking the house down. If you turn off the power and turn it on again it will be fine for a day or so and then it will happen again. Does any one know what the problem may be? Could it be the power plug/cord?
    Your help is greatly appreciated.
  2. RSD123
    RSD123
    It sounds like its maybe your reciever/amplifier or the amp in the sub causing the feedback. You could e-mail Paradigm (they have very good customer service, my dad had a problem with his psw-2100 that they fixed quickly). How is the sub volume and crossover set?
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I doubt whether it's the power cord. Sounds like a fault in the sub itself to me.
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    There's nothing obvious in the componentry you're using which could be wrong so I agree with Ian that it's probably a fault. Get in touch with Paradigm and see if they can help, otherwise it will probably be a repair or replacement job. :)
  5. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    The last sub i had did this and it was a loose power cord that was the problem,i would replace that first just incase .
  6. spikey1
    spikey1
    Jan 9, 2004
    459
    +18
    I had a PDR-10 which developed a similar problem causing me to go out and buy a REL Q200 and new cable.
    Just before I swapped the subs out I tried the new cable with the PDR-10 and low and behold no more feedback (yes I know).
    I kept the REL as I think it works better with music but I miss the very deep bass on films from the Paradigm and the gap in my bank balance!!
    So it may be worth changing the lead.
