Paradigm PDR-10 Vs Mordaunt Short 907w
Discussion in 'Subwoofers' started by jonnyv, May 5, 2003.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,282
    48
    +52
    I have a paradigm PDR-10 sub at the moment and am looking to upgrade, does anyone know how the MS 907w compares with the paradigm ?
    specs here:
    paradigm
    Mordaunt Short
    thanks
  2. mick23
    mick23
    Mar 20, 2002
    801
    uk
    pdr vs m/s
    last year i purchased pdr8(£120) from local rs,they did not have pdr10, only ms308 at £150,eltax,mission and the large paridigm,
    i wanted a small sub,due to room placement, had pdr8 for about fornight, wondered whether ms308 might be worth the extra £30 , so took pdr8 back and exchanged for m/s308, i did not do a side by side comparison, and to be fair tried the m/s straight out of the box, after sometime i felt the pdr8 did as much and slightly more than m/s308 (less flabby bass) so returned 308 ,and went back to pdr8,
    i am assuming the m/s you refer to is avaliably at rs for you to try /demo and see if you think its a "worthwhile"
    i stress this is my opinion only,
    there are others who can give you more experienced advice, who have owned pdr10 and what they upgraded to,
  3. jonnyv
    jonnyv
    Mar 31, 2002
    2,282
    48
    +52
    thanks for the reply mick23, but im talking about the MS 907w model not the 308.
    but thanks anyway
  4. mick23
    mick23
    Mar 20, 2002
    801
    uk
    yes j i realize that i was quoting differance (i found) between pdr8 vs 308, you are refering to pdr10 vs the higher spec m/short sub, so results could possibly be simular.
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,794
    87
    Newcastle
    +116
    The PDR10 is a very good sub for the price. If you want to upgrade I would be looking at one of the smaller Velos CHT-10 or VX10
