Paradigm PDR-10/12
Discussion in 'Subwoofers' started by belt, Feb 24, 2003.
  1. belt
    belt
    Was thinking of buying one these but not sure which to go for or if there is a better sub for a similar price.
    has anybody heard either of these in action?
  2. RATMARK
    RATMARK
    i use the 10 cost me £149 from richer sounds a couple of years ago,made a massive difference in listening,for the money im well happy.Having said that ive not heard a £500 rel etc
    it has developed a rather irritating mains hum though!
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
    I had the PDR10 and can recomment it. It certainly was not boomy in my environment and was easy to set up. It was situated in a corner in a 16 x 14 foot room. It was also not bad with music although I am not an audiophile
  4. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    If you can stretch your budget to £200 then Richer Sounds do the PS1000 has a sale item advertised in What Hifi magazine. This is another step up from the PDR10 but it is physically larger has well so will depend it you have the space for it. If you do decide to go for it then just keep checking What Hifi mag until they have it on offer again, this seems to be most months at the moment, then take the mag with you to RS.
  5. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Perhaps uncle eric will bag a Velodyne VX-10 powerbuy @£199.95 (as he has requested). I'd consider that if you can stretch to ~£200. Even at the list price of £249 it seems like a bargain.
    MuFu.
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
    What is your budget Belt, max?
  7. belt
    belt
    I don't want to spend anymore than £200,but if i heard something very impressive i'd be willin to stretch it a little more.Has anyone heard the HSU VTF-2 i've read a few reveiws that said it was a good budget sub but i can't find any shops that stock the HSU range.
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
  9. bobbetts
    bobbetts
    Dec 13, 2002
    154
    Norfolk
    Sorry to go off at a tangent, but my PDR10 has done the same. Did your sub literally suddenly do this, or did you have a change of kit, location, cable etc ?
    Also, the hum gets louder the longer the unit is plugged in for.
  10. RATMARK
    RATMARK
    i changed my amp from sherwood to marantz,this is when it started,it also continues if i switch off the amp ,could this be somthing to do with the earth etc
  11. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
    Howay lads - back to the origional question.
    Belt, have you come to any conclusions yet
  12. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    He did, lol. :)
    MuFu.
