Paradigm APD150
Discussion in 'Subwoofers' started by aj, Jan 13, 2001.
  1. aj
    aj
    Hi all
    I have a denon 10se (poat10 for the fronts)
    and I use the power amp part of the main amp for the rears.
    I was considering some Paradigm APD150s but looking at the power handling ability, I think I will blow them into teensy weensy little bits.
    I do like to listen loud.
    What are my options?????
    Price is a consideration Im afraid, cos I don't have a matress stuffed with used tenners.
    Advice please.
    Many thanks in advance.
    AJ
