Pany PW7BX Connections
Discussion in 'Plasma TVs' started by Pugs1, Feb 1, 2005.
  1. Pugs1
    Pugs1
    Jan 31, 2005
    1,128
    +112
    Hi guys, hope someone here can help :thumbsup:
    I’ve just bought a Denon 550(forget its a Denon just think of any AV Amp) and a Panasonic PW7BX and I’m having problems with the correct setup between these two components and a Sky digital box. The Plasma has 1 component and 1 scart board installed only.
    The setup is as follows
    Denon DVD component out -> Denon Amp component in
    Denon Amp component out -> Plasma component in
    Sky box -> Plasma scart (RGB) in
    Sky digital audio out -> Denon Amp digital audio in
    Is this the best setup for these components?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    with what you have yes (as the AMP only has on input you can take DVD pic direct to Panel
  3. Pugs1
    Pugs1
    Jan 31, 2005
    1,128
    +112
    Thanks,
    Is this a recommended way of setting up this Plasma/AV amp?
    The reason why I ask is this, basically I don’t get any ‘on-screen’ menu’s appearing for the amp through the screen. It makes life awkward for setting up surround sound levels etc. According to the amp manual once set up properly the amp menus should be available through the TV! Sorry for being dumb but I don’t understand this particularly well and I’m new to home cinema (always been in to stereo music – TAG stuff).
    Could I possibly connect the scart out for the Sky box via the amp and in to the PW7? Should or do I need to get another scart/s-video board for the PW?
    What would you do?
    Sorry for the questions but I’ve spend a lot of dosh and I would like to get this sorted.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    quite a few systems dont out put the on-screen menu via component best idea for sound set-up is to use composite from AMP to scart on plasma for sound set-up the rewire for use........
