Pany pw6/pw7 scart audio
Discussion in 'Plasma TVs Forum' started by Steve_Whelan, Oct 1, 2004.
  1. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    I have Decided to get a Pany PW7 37" with Scart board. I would like to know if the scart board handles the audio signal. or just the video.
  2. spook
    spook
    May 18, 2004
    157
    if it uses the same scart modules as the PW6 then yes it is fully wired and uses the standard stereo soundtrack, which can be heard if you connect a pair of 6ohm speakers directly to the plasma
    also, the component module for Panasonic plasmas has stereo phono connectors built in.
    if you use the VGA connection there is a stereo mini jack to go along with that connection too, so your pretty much sorted for stereo whichever connection you choose.
    Spook
